Whats this chip worth?
live1053rulz
Nor Cal SyTy
I've been wanting a chip for the Ty. It's pretty much all stock for now. What do you guys think this one is worth paying for? Is it the best way to go?
QUICK STORM
B.A.M.F. BMW Tech
Re: Whats this chip worth?
get and ultimate, 50#'s, adjustable FPR, walbro fuel pump, hot wire intercooler pump, replace intercooler piping with heater hose etc..this is what you should start with.
InvisiBill
The ATR Pitbull is slightly better than the stock chip. It uses open loop boost control (adjust the wastegate arm to set the boost level), and is a little richer so you can run a little more boost without going to a 3bar setup. Everything else is pretty much questionable.
The Ultimate was done by some SyTy guys, and offers many different programs, so you can usually find one that works well with your truck. You can also switch between the settings for running race gas and stuff too. It's still a standard tune, but you can generally find a setting that works well. It's 3bar too, so you can see more than 15psi. With a 2bar setup, everything over 15psi looks exactly the same to the computer.
The third option is to get a custom chip made for your truck. That's the best solution (as it's made just for your exact truck), but it will cost you the most time and/or money.
