whats this due??
Re: whats this due??
Its an EGR solenoid. It bleed off vacuum sort of like the factory boost solenoid does otherwise the EGR would also be on uin vacuum situations. Anyways if you don't have an EGR valve you don't need it.
WyoSyclone
It's the EGR solenoid - it controls the EGR valve.... I deleted my EGR valve with a blockoff plate, but left the solenoid so that I wouldn't throw an EGR DTC... since I'll be tuning soon, I'll probably delete mine too.
Flyin Ryan
hated cuz he drives fords
also in that picture (im guessing you know this already) is the MAP sensor which you do need
syclomatic
Syclone #2481
Hey, I have an egr delete, so do I need the solenoid? If so, do I still need to run vacuum to it? The person before me did the delete, and I am just now worrying about it do to replacing the vacuum lines.
Flyin Ryan
No you don't need the solenoid at all.. just remove it from the map sensor bracket and cap the vac port.
