Whats up with upper/lower spacer?
DanenGraham
Big in the rear
Ok, i was reading the othere post about this and was wondering why whould you put a spacer inbetween the upper/lower intake, I now on a carb you put the spacer so you dont cook your fuel befor it gets to the motor, but with the injectors being in the lower and not in the upper, What gives?
DG
Re: Whats up with upper/lower spacer?
I think it would be for mainly heat transfer to the upper intake. That is what the used to cliam (maybe still do) claim for the 5.0 spacers.
jwaller
Evil Genius/SyTy Guru
for the amount of time air actually spends i the upper intake. I think it's a waste of time. kinda like running your ic water throught the TB....
under boost I'd image that a parcel of air spends about 0.000000001 sec inside the upper intake. not a lot of time for heat transfer. :x
myclone
Waller is prolly right but..... after I made my spacer and installed it (EGR was already blocked in the lower btw) the upper was cool to the touch after over an hour of steady 60mph cruising. Prolly not worth much but it didnt cost me anything so I figured even if I got .5hp I didnt spend anything to get it.
FWIW.. IMO if you spent some time you could prolly make one in a few hrs with a jig saw then use a dremel for the final finishing.
FWIW II... The carb ppl have been make spacers/insulators out of high grade plywood for eons. Thay just cut out the shape they need then varnish/urathane it, paint the edges that you would see black, then install. Just something to think about for you DIYers and/or budget minded ppl.
G
Guest
Guest
I have a similiar post up in the "lounge" area seeking ready made phenolic spacers. I do agree that there isn't much performance advantage out of them for our application. I have my lower off to fix a minor water leak, and am interested in them as I currently have 4 of the gaskets to get my larger W2A IC to clear the TALL aluminium valve covers. I'd prefer something solid in there rather than mutiple gaskets.
I'm still seeking one in case someone has an extra already made hanging on the wall.
