cvcsmkr
i dm some runs since i got chip back and wb is working.
something seems to just not be adding up.
stock motor rebuilt with the typ forged rods, pistons, valves, stock heads.
kb a2a, te44(same as pte44), kb 2800 tc, walbro 255 , 50's, ultimate set on t1-16
okay here are the stats from a quick wot pass.
fuel press 46 psi
14 psi of boost
spark advance of 17
kr of 2*
iat's 110
afr 12.5
02 mv 1100
engine temp 160
13.5 volts across the board
inj dc 60
the idle is searching quite a bit.
if i cut fuel press a few psi the idle is great.
to me it sounds like i am running an abnormal amount of fuel press, but i am still slightly lean.
i dont get it??
fuel press 46 psi
14 psi of boost
spark advance of 17
kr of 2*
iat's 110
afr 12.5
02 mv 1100
engine temp 160
inj dc 60
i dont get it??
