what's your final VE numbers
turbotater
if i add f 29 table & f 30 table and multiply that by
the f 77 table i am in that 130% VE range
this is with 75 lb injectors with ported l-35 heads
and a 70 mm turbo .
does that look normal compared to other
similar combos ?
whatcha think
Re: what's your final VE numbers
VE really doesn't mean much, except larger = more fuel, less = less fuel.
Reason is, there are several constants, and other ways you can change VE yet still have the same fuel in the end.
With 75's some constants were changed to make it work.
In the end what does your wb o2 say? How does the truck run?
turbotater
i am just starting on trying to make power ( long story )
the truck drives fine under normal driving but was lean
i am only at 12 psi currently . my wideband broke so i
am back to reading sparkplugs and using datamaster
until i get another wideband . right now the truck probably
is at 7.70ish @88-90 mph 1/8 guessing from its past .
so i have a long way to go on tuning
mike
Although the stock o2 will give you some idea, it won't tell you everything.
So your left to plugs, knock, and how it feels. More guess and check then anything.
turbotater
unfortunately i am being slowed down without a
wideband but i still trust plug readings , just a
pain to blast it - kill it - replace one - evaluate it-
make a change and then do it again . although that
is the way i did it for years on cars . can't be to bad
i had a '79 trans am that ran 10.63 @132 back in
1991 that was a pump gas car i would drive 74 miles
to a track and then would drive home .
i was just trying to see what other people were ending
up with on VE numbers with semi built up combos .
i am guessing when i get the turbo on full boogy i may
have VE numbers in the 140-150 range . hope fully the motor
will live long enough to find out
Black Knight
I Glow Therefore I am
T-56 said:
I have no idea what you just said... :robot: :eyes:
Every time I read anything by you I about piss myself, because its so off the wall, keep up the good work soldier! :tup:
