Wheel cylinders
RScal
Just Getting Started...
Question for guys...with the ABS getting kicked to the curb on my Ty, I want to upgrade to the bigger shoes and cylinders...
What's the PN# to use for the bigger wheel cylinder and what shoes did you go with?
Thanks...
Re: Wheel cylinders
To get 2 longer shoes usually you need to buy 2 set of shoes. I personally don't think it's necessary. I don't know which wheel cylinders use with Typhoons. The Syclone just uses an early s-10 with manual brakes for a 7/8 wheel cylinder that fits.
berzerker
wookie
Re: Wheel cylinders
do yourself a huge favor and just upgrade to ls1 rear brakes rather then messing around with the drum brakes .
Re: Wheel cylinders
From other post responses over the years the following part numbers may apply and I hope you are successful:
GM #: 18015812
AC Delco #: 18E3171?
Raybestos #: WC37854
Wagner #: F110261
Advance Auto #: WC37854
Bendix #: 33892
Autozone #: 33892
NAPA #: TWS4637854
United #: 37664
These may be either bolt-in type or clip-on type (Sy vs TY) as previous posts did not always clarify. These part #'s should be a good start. Good luck.
RScal
Re: Wheel cylinders
Thanks...
GM #: 18015812
Wagner #: F110261
Bendix #: 33892
Autozone #: 33892
NAPA #: TWS4637854
United #: 37664
