I searched and found nothing on wheel hub dimension.
DanenGraham Big in the rear Apr 12, 2013 #2 Re: Wheel Hub Dimension The axle hub diamiter is 2.74" and is the same as what the corvettes run. If that is what you are looking for.
93 TY 2185 Donating Member Apr 12, 2013 #3 Re: Wheel Hub Dimension DanenGraham said: The axle hub diamiter is 2.74" and is the same as what the corvettes run. If that is what you are looking for. Click to expand... This is what I found on a Adapter makers website... 1993 CHEVROLET_TRUCK S-10_PICK-UP_2WD_4WD Your Bolt Pattern: 5x120.7mm Your Hub Diameter: 70.3mm 2.74" comes out to 69.596
C Captain Morgan Moderated User Apr 12, 2013 #4 Re: Wheel Hub Dimension this is all I could dig up... Attributes # of Mounting Bolts/Studs : 3-M12 x 1.75 # of Splines : 27 Bearing Type : Ball Brake Pilot Diameter : 70.6 mm Hub Pilot Diameter : 91.9 mm Mounting Hole Diameter : 120.65 mm Wheel Pilot Diameter : 70.1 mm
