Re: Wheel spacing
Measure your OFFSET on the current wheels and then adjust it for the spacers.
To measure the offset, lay a straight edge across the back of the rim (not tire) and measure the distance from the straight edge to the mounting surface. That is the backspace, and the offset will be the difference in that and the centerline. For Example: An 11" rim has a centerline at 5.5" so if you measure a backspace of 6.5 then the offset is +1" likewise if you mesaure 4.5" for a backspace then the offset will be -1". Most wheels I have come across refer to offset more than backspace but it would be good to know both.
Hope this can help you determine what you will need.
PS... Don't forget to adjust your measurements for the spacers that you had in there.
I'm pretty sure you'll have a positive offset on your current rims so just SUBTRACT the spacer measurement from the offset and/or backspace. That will be your new offset/backspace numbers and you should be ok without spacers.
