When good 700R4's go bad
SY2932
Administrator
Well, I finally got around to getting all my pics of my "fun" before the NATS off my digital camera. Some of you might remember that my transmission went two weeks before the NATS: http://syty.net/phpBB2/viewtopic.php?t=15623&highlight= I took a few pics to amuse the syty masses who care.
This is why I'm glad that I have a 2 car garage: http://www.chitownsyty.com/gallery/view_photo.php?set_albumName=2932&id=acv
If you have ever pulled your own transmission, you know what's up with this sheet metal mod :-?: http://www.chitownsyty.com/gallery/view_photo.php?set_albumName=2932&id=acw
The transfer case wasn't as heavy as I thought it was gonna be. Either way, it's still enough to hurt ya if it gets away from you when you're taking it off: http://www.chitownsyty.com/gallery/view_photo.php?set_albumName=2932&id=acz
About a week and a half later and $592.20 less in the pocket I get back my rebuilt transmission with these busted ass parts. First is the sprag that was torn in half: http://www.chitownsyty.com/gallery/view_photo.php?set_albumName=2932&id=acy
Second was the planetary carrier with all the teeth in the center stripped out. The guy at the transmission shop said he's never seen that done before :p : http://www.chitownsyty.com/gallery/view_photo.php?set_albumName=2932&id=acx
I removed/replaced my transmission by myself. It was the first time that I had ever pulled a transmission-ever. A BIG thanks go out to George B. and Jesse A. for posting how to do it on Jesse's webpage http://huryde.com/html/Tech/sytytechmofo.htm
:D . I planned to pull my transmission before I took it to the shop. After I found out how much they would have charged to remove/replace and rebuild was happy that I did it myself because I saved over $700 :eek: . Only goes to show if you have the time, know how and tools to get the job done, you're better off doing it yourself. Just hope to learn enough about 700R4's before the next time it goes so I can rebuild it myself...
Mike Campbell
Ian Turgeon
Cascading Inspiration
Re: When good 700R4's go bad
the 2 sprags ive seen broken look different.. am I thinking of a different part of the sprag, or is yours different?
the ones ive seen, its a ring of a bunch of lobed metal pieces that ends up all bent outa shape and missing some of the lobed pieces.
SeattleSy#1255
Category 5 Conservative
My brother, I blew my tranny too. I was thinking about doing it myself, but I have zero experience...does it take any special tools? Can I take it out myself then fix it myself? Where can I get parts--can i get a kit from hartman? I was thinking about it and seems like you did what I want to do...thanks for info bro.
myclone
Welcome to the "pulled the trans by myself club" Mike. Not the most fun Ive ever had when I pulled mine for the 9/11 install but it can be done with much cussing and a few beers.
I noticed you have the same jack stands I do and as you prolly discovered they arent tall enough fully extended to get the trans out while its still on a jack. FWIW I made some "extensions" out of 2"x2"x1/8" thick steel square tubing to put under em. I made them so I ended up with an extra 4" of height which gave me just enough room to roll the trans out from under the truck.
Also I didnt have to do any sheet metal mods to get mine out. I pulled the dist cap off for clearance, pulled the trans cross member, put a bottle jack under the sump on the oil pan (using a block of wood to protect it), and used a floor jack to lower the rear of the trans enough to get at the upper bellhousing bolts. It gave me a BUNCH of extra room to get at the fittings for the trans cooler lines also.
Anyway.. IMO you have now earned you stripes in syty land. :wink:
B
Blake
Guest
That part that is shown as the sprag is the overrun clutch hub thats held over the sprag's race with a snap ring. I want to see carnage! There had to have been more busted parts than that. I bet that sprag looked like a twisted coat hanger. I bet the rear sun gear looked nasty too. Hopefully they replaced your rear sun gear shell with the newer style. Little beefier where that rear sun gear chewed up stuff. Did the output shaft survive?
Glad your fixed up.
Blake
