Re: When is knock audible?
My truck is fairly quiet. I log data constantly. I have gotten used to listening carefully for knock and reviewing data logs. My audible threshold is ~ 3-5 deg knock retard. I am never able to hear knock that occurs at shift points, and wonder if is real. The knock sound is in very short bursts and sounds to be somewhat above the 88th key on a piano. It does have a metalic ping sound, but much shorter than a ball peen on metal (crisp and no ringing). There is sometimes a secondary sound like marbles in a soup can, somewhat like a diesel truck. The knock sensor system seems to really work well. Anytime I hear knock, it is surely there in the log. The trouble is the log often shows knock that I do not hear. It has traced to a loose bracket on the engine or motor mount in some cases. Some of the time I cannot find any reason for it.In that case I add some leaded fuel, and ~80% of the time it goes away. Sometime I would like to spend more time looking with the oscilloscope. In the past I havent been able to trigger the scope on actual knock events.
