Throws
I've recently been troubleshooting a issue where my Ty was stumbling at idle, and had on occasion died.
http://www.syty.net/forums/showthread.php?t=95022
Well... I think I might have found the issue: a broken/split MAP sensor
I found it when I was doing a bike tube (inner tube test), and after plugging two leak on the throttle body (loose vac cap on top, lower PCV hose sliding down), I kept hearing the noise coming from the MAP sensor. It was a MSD 3 bar MAP (# 2313), and I had no reason to think it had gone bad. I popped it loose to check the hose, and found that the top had separated from the bottom and the insides loose. I found it very hard to believe that the MSD was so cheaply made that it blew apart under boost and could easily pass for a Chinese made eBay $25 cheapo. So, I've got a new Delphi 3Bar on the way from RockAuto, which after seeing how the OEM one was put together, gives me greater confidence in lasting longer... much longer.
I had chased down testing Ostrich2 units, bad ECMs (on #3, 2nd remanned), plugs and wires (did find a cracked plug!), I'd even repinned the entire ECM side of the harness... this was an exercise in frustration and to a degree, patience.
If this next one fails, my next unit will be a VEMS(https://shop.vems.hu/catalog/sensor-p-89.html) or a Omni Power (http://omnipowerusa.com/product.asp?P_ID=158).... anything but an MSD.
MSD Internals (Notice cheap wires and RTV'd MAP sensor)
GM OEM (was unable to open MAP sensor itself)
Many thanks to those that helped and spent time with me diagnosing it: (Dave, Rob, Scott, Rod and Mark)
-P
-P
