Where can i get vac. line kit
White97SVT
Some time this winter i want to replace all of the Vac line in the engine bay. I don't see any broken or crakced lines yet, I figure that the truck is about due to change them. I can see the stock ones around the turbo look to have a little wear from rubbing.
I know that Ian was making the kits a while ago. Does anyone know if he is still doing that or if he has stopped. Are there another other good place to pick up a vac line kit.
thanks for the help guys.
Lee
ed hess
race or get outta the way
just buy some vac hose off a roll and go at it.
i never quie understood why anyone needed a kit.
i mean anyone can cut the length needed and put on some wire ties....
ed
syclonekid43
i think what lee wants is the kit that somebody on here wan making. the vac kit was made from silicone. i want to get the same kit for my syclone. do you guys know of anybody who sells silcone vac lines by the roll. i figure this way i can do his and mine at the same time. i did a search and came up empty.
White97SVT
ok, So i think i am just going to go out and by different lengths of silicone vac. hose. What diameter are the vac hose in the engine bay? How many feet should i get to do the whole engine?
Flyin Ryan
hated cuz he drives fords
Can't really remember how much you need but the sizes are 4mm and 6mm if I remember correctly.
Ty0279
Historically Significant
You'll need 15ft. of 4mm hose, and 10ft. of 6mm hose.
You can re-use the stock T's, elbows, and check valves if they are in good shape.
You'll need some zip ties too.
ed hess
I kinda remember the oem zip ties haveing metal in them.
never seen these for sale anyplace!
ed
