Re: where do all vacuum lines go?
Check valve question.
Re: the check valve that the cruise control connects to (the top valve on the diagram above). Mine is pointing the other direction - the pointy end of the valve faces the front of the truck, while the diagram shows the pointy end facing the firewall. I think mine is right because the cruise control line on mine is still on the firewall side of the check valve.
Can anyone confirm that the diagram above has the pointy end facing the wrong way?
