pull the pas side kick panel, remove one screw then reach up and pull her down slowly
Up under the dash behind the glove box like Jimmy has stated . Chipping a Syclone requires a certain level of "knowing what to look out for" after its install though. Do you have the other basic essentials installed already ? That is not a cheap shot at your skills tool box , I just wouldn't want to see you damage your truck after you start changing things . Its doesn't take much for the jackstands to be needed but if you ease into it , you should be fine .
i think im on the right track . i got the truck a year ago and i finally my truck running good a couple months ago . i got a 160 thermostat in it .igot rid of the stock air intake . what do i have to look out for
