Where is the heat sending unit?
Baja Resident
Another issue. The truck never heats beyond 100 on the gauge. I just replaced the 160 therm with a 180, thinking it would help, but no. It also just had the heater core replaced last week. Problem persists. I figure it may be the sending unit since the truck gets hot fairly quick and blows very warm in the cold. Any pics or really good directions to where it's located?
TIA
TYRODD
My ass. Look at it.
Re: Where is the heat sending unit?
TIA
There are to coolant sensors on our trucks, one for the guage, and one for the ECM signal. One is next to the thermostat housing, and the other is next to the drivers side exhaust mani, between the #1 and #3 plugs.
Now, I believe the guage sensor is next to the thermostat, and the ECM sensor is the other, but Im not 100% positive...someone please chime in here :D
Captain Morgan
Moderated User
reverse that :)
the sensor in the drivers side cylinder head (and I believe its between #3 and #5) is the one for the dash gauge, and the one on the manifold is for the ECM.
Tydriver
TurboLS6 Powa'
Baja Resident said:
Thanks. Seems easy to access from the wheel well then I assume?
Naw open hood.. U will see wire coming down to sensor.. And to the best of my knowledge, Morgan is correct...
