where to put an xternal gate
black cat
i disconnected my internal gate completely. took it out for a spin and the boost still goes over 15. this is with a holset wh1-c and a 3 downpipe that i just installed. idon,t think putting a cat on will fix this. any picsof xternals installed thks
black cat
Re: where to put an xternal gate
what is the gate set to on the spring.any boost creep with this set up
Yukon Jon
Good luck to you. Dont know if you can run the stock fan with that setup im running electric fans.
black cat
i have an electric fan. if i put it on the cross over it will only exhaust the left bank. the holset stock internal waste gate exhausts the right side bank only. i,m not sure it would work much better.i,m at at 15 psi by 3000rpm with the stock gate wide open at half throttle
SyTyAddict
I don't know if this will work with what your doing, but you could put a spacer in between the turbine housing and the manifold; the downside is the downpipe might need some reworking. On the next turbo upgrade I do, I'm going to use a v-band inlet/outlet turbo with a spacer pipe where I previously mentioned and tap into it for the external gate.
If that won't work, then at least maybe it will help in coming up with more ideas.
black cat
when i built the downpipe it was in the back of my mind to put that adaptor in. i,m still flipping on where i,m going to put the gate.
