Where to send injectors?
Trapper
I have a set of injector that I'm trading for another set but I want to make shure he dosen't get a bad one. Where has anyone sent there injectors to get them check out? These are only over a year old from RPM so I dont know why they dont work in this truck right.
DRUNK411
Re: Where to send injectors?
Is it possible to clean your injectors or test each one to see if they are bad or not yourself?
Trapper
I check the ohms and they were all about the same 2.5 I think but I just switched to stockers and can throw in a some what stock chip and it runs OK. I don't know much about injectors or programming because I just started using code59, but I just downloaded a few from code 59 and it seems to run fine I will take it for a spin when it stops raining.
I might send them to the shop suggested near Austin Thanks guys
CarbonFiber AWD
Sure....you can always take a 12v battery and a good fuel pump and bench them . You'll need a science type beaker to watch/count the cc's and a stop watch . 30 seconds run on each a few times with either gas or Laq. thinner .
That will allow you to watch their spray pattern and capture their CC match. The OHM's will tell you some things too.
Cheers,Vinny
Trapper
I have seen a few peoples homemade test benches online I might have a good idea.
I have a fuel pump, battery some hose, need to find a switch, I can do that.
Trapper
Well I have been also suggested to send then to RPM with the receipt?
