which blow off valve
98darkhorse
Im looking into blow off valves but not sure what one to get..the only thing I know is that you need to play with the spring pressures to get it to work right with a current motor set up...also some sound different...I dont mind it being loud but not retarded loud
Also is there any issue when using water meth injection with some of the mix being sprayed out the b.o.v....I dont want that crap all over under the hood
atkonkler
Is this your bush?
Re: which blow off valve
This is what I used by JGS....very simple...not over powering and annoying noise when it releases pressure and the guy there was very helpful with any questions....All you will need to do is find someone who can weld aluminum so that you can put a flange on the turbo to intercooler pipe. ..my guy welded mine for $30... The meth injection is done after this into the upper part of the intercooler and rubber intercooler connector to the throttle body..http://www.jgstools.com/turbo/wgpg.html
e95 Ty
Just fyi, the spring pressure has nothing to do with boost only vacuum on a bov...You should match the spring with your vacuum at idle.
I'm always and advocate for JGS: made in the USA, good guys, quality product and a good price. They do offer a stainless flange as well, which anybody can weld with a standard mig and stainless wire - just and option, if you don't go aluminum.
Aeroking
e.i.
http://www.siliconeintakes.com/product_info.php?cPath=11&products_id=456&osCsid=3af6d979a8edc5758beffcbde13e0635
if you have a stock intercooler you can run this for $25 with some couplers.
i use a HKS SSQV, cheap and theres no adjusting anything.
