which brakes are best?
s_blazin
i see a few guys on here making brake kits or guys buying brake kits for their trucks
LS1
C5
C6
ZO6
ETC ETC
so which one is the best out of all of them?
is bigger always better or do some squeeze harder?
whats the best bang for your buck?
trying to decide what i might go with,
Z SKI
Re: which brakes are best?
Well from what i gather, the fronts are pretty similar. 98-02 f body are 12" rotors with 2 piston PBR caliper. C5, C6, and C5 ZO6 are 12.75" rotors with 2 piston PBR caliper (similar to the LS1's but have bigger pistons and are paited different colors), C6 Z51 are 13.4" rotors with 2 piston PBR caliper, and the C6 ZO6 uses 14" rotors with 6 piston calipers.
In other words most of the systems that you mentioned are pretty similar. Ls1's are good because they fit under the stock 16" wheels. C5, C6, and C5 ZO6 require 17" wheels. 18" wheels for the C6 Z51 and i think 19" for the C6 ZO6.
I am going to run C5 12.75" baer rotors with f body front calipers and f body 12" baer rotors with f body rear calipers on my truck. Chris from CBR said that running the f body calipers with the 12.75" front rotors equals a very good front brake package as the f body calipers have more clamping force than the C5 calipers.
Hope this helps.
See ya,
Black Knight
I Glow Therefore I am
It can be confusing, because a lot of people label the 12" brake setup as the "LS1" setup, which doesn't make sense since the C5 Corvette has a LS1. More accurately it should be labeled the F-Body setup (since they came with 12" rotor), which even that isn't accurate since the '98-'02 Camaro SS has the 13" C5 Corvette set up on it, with calipers labeled Camaro SS.
Bottom line, is the larger the rotor, the more surface area you have to dissipate heat, not only in diameter, but also in width. Better heat dissipation = better stopping ability, but then your tires come into play. The brakes on my Z06 are comparable to the C5 setup and they stop great, problem is the stock Goodyear tires are trash and don't hold for crap, so the car will just slide instead of put you through the windshield.
All the info Paul put up is accurate, so like going fast it all just depends on how much you want to spend.
One thing most people don't know is that C5 rotors are directional, even the blank ones. There are flutes that run down the center of the rotor to help with the cooling process. So besides just surface area, they also have that advantage, I wonder how many people have them on backwards and don't even know it, LOL.
warmpancakes
blonde or brunette, yes bigger brakes should stop better but they also make the truck accelerate slowly its a fine line, personally i have 13 inch fronts and 12 inch rears on the ty, why well because thats how i roll
TT350
Manufacturer
Now you can have your cake and eat it too.
This new bracket will accept the 12"F-Body,13"C-5 and the C-6 brakes!!!!
So if you want to change your brakes from one to the other bolts spacers and shims
are all that's required.
I am cutting the brackets as we speak.
The hoses should be here any day now.
Mtn Z
No, all F-bodies have the same brake system. The SS did not get an improved brake system.
Z SKI
Corrected my above misnaming. And as my bald brother said all 98-02 f bodies, even v6 cars had the exactly same braking systems.
See ya,
Black Knight
Well all I can say is there are two SS's, one that's sitting right in front of my house at this very moment and one that is a good friend of mine with the setup I just stated on them. Both have the SLP setup's though so that might make the difference. I know for a fact that these guys didn't upgrade the brakes any farther then putting on cross-drilled/slotted rotors, because I helped.
Either way you can include or not include the SS, but the point I was trying to make is that labeling the 12" rotor setup as "LS1" is incorrect.
Six-is-Enough
Use to do a little Boost
Any of the above brake rotors and calipers are major improvements over stock Sy/Ty stuff! I have F-body discs on all 4 corners and have no complaints. I would also recommend a Hood ABS delete kit upgrade too!
warmpancakes
THE 98-03 CAMARO f-car ALL USED THE SAME REAR BRAKES, but the mounting bracket was different between traction control and non traction control cars, if you have a syclone and are keeping the abs you need brackets from a car with traction control typhoon or dumping abs it doesnt matter. There were 2 different front brakes offered v8 and non v8 slp did not change the brakes there was a suspension option,
Mtn Z
Actually, I hate to be a dick about this but the front brakes are also the same across the board. The brake system is shared between all V6 and V8 models. I have owned and been a part of the LS1 generation of F-bodies pretty much since its inception and I have done lots of research about them. You can pull the brakes off of any F-body and you are all set. :tup:
warmpancakes
no problem according to GM the front calipers are different? but thats good if they are the same makes the parts much easier to find
Mtn Z
It's no big deal. ;) I was just sharing some F-body knowledge. They changed the brakes when they changed the front end in 1998. The LT1 body style had the smaller brakes. It's actually quite convenient that they are all the same when visiting the junkyard or something. :tup: V6s are everywhere.
'JustDreamin'
Dream: 6LV8 Turbo Bravada
As a F-body owner, I find GM to just be amazing at some times.
Case in point: The above statement that the brakes for the V6, V8, and SS cars are all the same. Wouldn't you think that the LS1 V8 cars (which were rated at 300hp and everybody knows they were under-rated and were putting over 300hp down to the rear wheels) should have better brakes than the 200hp V6? If you were buying a Z28 with twice the power as the base car, wouldn't you have expected better brakes? Yup. Did you get them. Nope. And they wonder why they have trouble selling cars.
2nd case in point. F*#%(n 7.625" 10-bolt rear in Z28's. V8 power, manual trans, and the weakest rear around. What's worse is that GM figured out that they needed a better rear in the V6 5speed S10's in about '95 or '96 and upgraded those to the 8.5" 10 bolt. But what did the f-body continue to receive? The same POS 7.625" 10-bolt found in the VEGA!. Brillant!
End rant.
All of the brake options listed are good choices. Engineering is all about compromises, and in this case deciding what the best brake system is depends upon your evaluation criteria.
Such as:
Cost.
Brake torque.
Replacement parts availability.
Required wheel diameter.
Available tire traction (best brakes in the world won't help if you can't get the stopping power to the asphalt).
Asthetics.
Fade resistance / thermal capacity.
Rotational inertia / system weight.
Expected service life.
ETC.
Lots of things to consider. Really depends upon what you want to do with the truck.
'JustDreamin'
Mtn Z
Agreed. I HATE how they put that rearend in my car. I mean seriously, what did GM engineers think we were going to do with the car. Worst decision ever.
Z SKI
Yea, how many sets of gears have you make go kablooee? :rotf:
s_blazin
so since my truck is just kind of a driver, with a few mods i'd probably be best off to just get the brackets from tt350 and use the f-body rotors and calipers since i would like to be able to put 16's on my truck for the track?
sounds like the f-body setup is the cheaper, but good bang for your buck kinda thing?
