which cam with the t56?
sean
what cam would you guys reconmend 412, 415, 422? i am putting the engine into a mazda pickup with a 6 speed t56 going 373 rear end.
Boosted Thrills
Re: which cam with the t56?
i run the 270AHR i think thats the 422. runs real good got as much as 27mpg with the 3.73 gears. runs even better with the blower
sean
daily driver but when i need to race i could. i'm going to go carburetor and turbo with that motor. boosted, how fast is your build? since i'm having almost the same build but with a turbo
Why do you want to use a carb? You can make an injected motor run stronger more often. Carbed motor is goign to give you lots of troubles in the long run, specailly if it is turbocharged.
I say, for a Daily Driver, go for the 412. That should be enough for you to have some fun with. And I strongly suggest keeping fuel injection. but you can make that decision on your own...
sean
with the 412 and 6 speed won't the truck fall on it's face? the 422 cam is at 2000 to 5500 rpm with the 412 is 1200 to 4500 rpm. with the 412 don't you think i would run out of rpm for the t56 tranny?
QUICK STORM
B.A.M.F. BMW Tech
carbed will suck cause then you have to dial the carb in along with the turbo, just a waste of time. so much more potential with EFI.
sean
i'm going to keep my ty efi just trying to do somethig diff for the engine i'm building for my mazda pick up. i have all the stuff to go efi but just thinking of going carbuator (suggestion from my engine rebuilder) still how well will the 412 cam work with the t56 tranny?
unless you are going forged and light weight internals, I wouldn't rev the stock engine over 4800 RPMs. Keep the EFI and don't listen to what the engine builder has to say about fuel. He might know what he is doing on BB drag cars, but the new days are here and a computer can control your fuel much better than a carbuerator can with a controlled leak on a daily driver.
I think the 412 will work great with the T56 tranny. Does that help? =P
edit: 1000th post!
Those RPM ranges are for N/A engine, most SyTy's with 412 run to atleast 5500 PM
sean
i due have all the forged stuff for my build including srp piston and h-beam rods and nitroed crank etc. thats good to know that i can rev the 412 to 5500
