Which cylinders are the leanest running?
syclone3
I have a set of cleaned stock injectors just back from RC engineering. I want to install them this week. Since I have the flow numbers for each injectors. Which cylinders should get the highest flowing and which the lowest? I saw talk of it before on here but can't find the thread after much searching.
This is a stock truck with a chip, regulator, pump and test pipe. Runs 18 psi on 100 octane all the time.
Re: Which cylinders are the leanest running?
IIRC, it's the front 2 cyls that are leaner than the others.(1 and 2)
edit: According to this thread and this post, the rear cyls run leaner than the rest. JWaller stated the rears run fatter, though.
syclone3
I'll put the highest flowing injectors in the rear. Going to portmatch the upper plenum to the gasket and clean all the carbon out. Only has 66,000 miles.
