Which Data recorder and chip to get
Couger1968
Dazed and Confused
I am not sure which chip to get. I have a hand held scanner with live data and limited recording(15 Seconds), but doesn't hook to a computer. If I go with a Moates set up from Hoodtuned (($355) I get everything I need, and is more flexible, but complicated. If I go with a turbotweak ($139) I need a cable ($75) and it looks like Datamaster ($114),it looks easier , but not as flexible. Does tunerpro($35) work for turbotweak chips? I am not looking at getting into hard core tunning, but have changed my heads and cam, with a possibility of a different turbo. I just want a safe and reliable tune.
Gnocide
turbo game burt reynolds
Re: Which Data recorder and chip to get
i use tunnerpro its free( if you have a scanmaster you dont need an aldl cable it will plug right in) that will save $59
tunnerpro rt is just $39 and even more enhanced
i use a scanmaster to keep an eye on things daily driving $250
i use turbo tweaks adjustable chip $139- change something in the truck- make the adjustment( not injectors)
hth
randy merritt
What is your budget? Do you plan on keeping the truck long term, or is it something that you feel you will move on from in the future? I tuned on my truck for years using Code 59 and the Moates setup before recently switching to the Holley HP. If I had it to do over again, I would have went straight to the Holley HP and skipped all the grief of tuning with Code 59.
Couger1968
Dazed and Confused
I want to keep it relatively stock. I have had it for 15 years and plan on keeping it a while. I finally finished restoring it this fall. I am not looking on spending a fortune and my hand held does a good job monitoring things, but lacks computer connectivity. I am not sure it would read wideband, but the gauge will do that. I guess that is the root of my question is cost.
randy merritt
Then I would suggest the Turbotweak chip and use Tunerpro to monitor and record data. You can patch your wide band into the stock computer and then be able to monitor and record it with Tunerpro.
Couger1968
Dazed and Confused
I was wondering if tunerpro read turborweak chips. It doesn't really say on the site. If that works then it probably is my best bet. $230 gets me going, and if I decide to change turbo I will have to modify the chip then.
KYTY
Glad to see you getting your truck back together. You helped me a lot in making some of my decisions thanks a bunch
Jim
Gnocide
hth
tuner pro reads your cpu regardless of chip
above is how it connects without an aldl cable but it will connect either way
Couger1968
Dazed and Confused
Thanks it is good to know. I am planning on changing it right away in the spring. I only got to put 150 miles on it before it snowed up here.
I use tuner pro for datalogging with my code59. I am a little bit of an odd ball person who like to looks my raw data in excel files so that works best for me.
Datamaster displays the data in more user friendly format.
Gnocide
i like the graphs instead of the gauges in tuner pro.
lets me know where the low spots and high spots are across the the run.
plus you can load into datazap!
Couger1968
Dazed and Confused
Is there something I can download for tunerpro and my ultimate chip to kind of get a baseline.
anryo
Can we use Hypertech chip instead of Turbotweak in similar setup, or are the different in this matter?
You could data-log the hyper tech chip with data master or tuner pro. You probably just going to see that your truck is over boosting at WOT. I personally would invest my money in better chip than an out dated 2 bar chip from the 90's that didn't even work that well when compared to ATR chips of the time.
anryo
Is it possible to write custom tune to Hypertech?
johnboy89
I've used both Tunerpro and Datamaster and DM was always more user friendly and like someone else said viewing the graph for analysis.
I've always felt that continous monitoring should be a must on these trucks, now that they make Scanmaster, it should be something every owner invests in.
You use the Hypertech carrier to swap proms (memory chips) or connect an emulator to. The most likely usage would be swapping ultimate tunes or DIY tuning with code 59. If you were to bring your truck to a tuner, more then 99% of them would not know what to do with your hypertech.
