Which Datamaster and why?
bdydrpds10
Yes I drive a Typhoon.
Ok, I searched and came up with a lot but it is confusing to me.
Can you guys please clear some things up?
I have a stock ty w/ 105,xxx. How exactly would datamaster help me
out? I know it helps tune the truck but does it help diagnose problems
as well. ( I would also like to keep it as stock as possible)
What is the difference in the datamaster you download free off
the web and the others? Ex. (Ones on Detroit turbo for $189?)
Sorry I guess I'm a little slow.
Any info would help Thanks in advance!
sytyguy
Moderated User
Re: Which Datamaster and why?
The DM you can download off of ttspowersystems.com is a demo (~20 free records and then you have to purchase it).
Hood
kwick6
The free download is limited to 20 recordings. The software is $100, and the cable is $100 from TTS. Actually I think its a little over $200 for both.
If you don't plan on doing any mods, or don't wrench on your truck, then its not going to be any help. Datamaster just helps you narrow down problems by looking at the whole picture, then you can see where your problem is and focus on it.
bdydrpds10
Ok, that makes sense about the "free" download.
As far as "wrenching" on my truck I do all the maintenance
and up keep. I plan on taking it to the track. When I say
I want to keep it stock I just mean no aftermarket turbo
upgrade or injectors etc.
So would the Datamaster help me tweak out better
numbers in the quarter?
Yes, it really is helpful to fine tuning your truck. Its helpful for seeing if the truck is in good runnng shape (out whack sensor) before even going WOT. At WOT its good for looking at Knock Retard, O2's (fuel delivery issue), WOT Voltage, MAT, boost control among other little things. Ofcourse you need to know what to look for, but that comes with experience and search/questions.
Jimmy
Banned
You do understand that it's just a datalogger,right? It's not like it can change anything about how your truck is running,it just let you SEE what it's doing,which CAN help you go faster.
bdydrpds10
Oh..... so you can't just push a few buttons and change the
air fuel ratio, etc.? I guess these trucks don't have some
sort of programer like the newer vehicles?
Jimmy's right. I should emphasized its datalogger, that you see what your engine is doing. The newer vehicle power programmers do very little, usually only changing constant (speedo corrections/fan temps) You can do on the fly changes with a Romulator. I have one but I rarely make that make changes at the track, I usually just change programs that I already created to test them.
