Which ignition component?
  • Accel
    Votes: 0 0.0%
  • Borg warner
    Votes: 0 0.0%
  • Other
    Votes: 0 0.0%
  • Total voters
    1
hatrik8
I ordered an accel gold cap 8133 at advance today to come in friday, but I can't decide if i want that or something different. I read old posts and people say accel is fine conrad is best etc etc. Should I use the accel or something different? What do you guys currently run?
Anyone have the part number for the conrad? Is it DR2012G?
I also got ngkur5 plugs cuz I heard they are just as good as the cr42ts plugs. Any input on that? I want to do this right when I tune it up. Is there any thing else anyone wants to share so I can get my baby running like the well oiled machine it is!?
Wes
As long as the cap is made with brass you should be fine. Also check the coil, it can corrode over time because it's made of some cheap metal. Gap the plugs to .035 and you're good to go.
SY2932
Administrator
Like many others, my truck idles better with the NGK UR5's (2771) than the tried and true CR42TS plugs. Been using them for three years now (not same set) with no problems. They seem to last as long as the 42's IMO. I only use Conrad caps in my truck. Get about two years out of them between replacements. If you still have your stock rims, you should have a tool to make removing the rotor lots easier: http://www.whitetyphoon.com/removing_rotor.html HTH's
