which is better (opinions wanted)
9
92IROCR/T
Guest
Well here it goes. I have a air to air intercooler (of course highly upgraded) and my roomate (who has a syclone) has the air to water intercooler. Which do you think is better and why? And are there certain ones for certain applications you should use?
Wes
Better for what? This has been debated a lot. Air/air for street, water/air with ice box for strip.
ParTyBoy
That's the conclusion most have come too...... you can heavily ice a air/water setup for a 1/4 mile run.. However, once the liquid becomes heated it can't release heat very fast... this is due to the density or mass of the liquid... It takes more energy to initially heat, but unfortunately liquids tend to retain the heat...
Since air doesn't usually contain these same attributes, it makes a better setup for street racing or stop and go driving, because instead of only a 1/4 mile run with iced liquids you are running constantly... An air 2 air setup can shrug off heat as fast as you've attained a forward velocity..
Only bad attribute to an air 2 air setup is when you are at a hault.. since no air is circulating... of course this can be remedied with electrical fans....
2kwik4u
Resident slow guy
Wut about......
Wut about......
Overall intake temps? Which one would produce the lowest/most consistantly low intake air temp?? The Air to Air??
ParTyBoy
Re: Wut about......
Re: Wut about......
From what I remember Air to water can produce below ambient... the coldest temperature... however, like I stated before.. Air 2 Air can produce close to ambient temperatures... If you're more into street racing or driving your vehicle then Air 2 Air is the best option... If you're only going to race youre truck one 1/4 mile at a time then Air 2 water is a better choice since you can ice down the IC or fluid.....
