Which shocks for lowered trucks???
Syclone#2960
What ever it takes!!
Time to change out the suspension on the Typhoon. Which shocks work better for lowered applications?:2cents:
Mephisto
These trucks are cursed
Re: Which shocks for lowered trucks???
I've heard some people say theyve had good luck with the kyb monomax on lowered trucks... i havent tried them... i bought the koni's for my syclone and they were shot after 20k... my sy has 3" blocks and the torsions turned out about 2"... they replaced them for me under warranty, and gave me brand new shocks. only these say they're truck specific... so i dont know if theyre any better than what i had. I think im gonna try and sell them and give the QA1's a try.
Anyone using the QA1's on a lowered truck without the coilover set up? how have they held up? I did a search and didnt really find an answer to that question... everyone just said "yeah theyre expensive but theyre great". Havent heard any input from anyone thats had them for a long period of time.
Syclone#2960
Good info...I will try out the KYB Monomax's.
Front Part #565048
Rear Part #565047
Syclone#2960
Suspension replacement instructions & tips.
1. Jack up the truck onto 2 jack stands or 2 jacks under the door areas..
2. Pop the hood for access to shock bolts.
3. Remove both wheels and place them under the frame in case the truck falls of the jacks.
4. Spray some PB blast or wd-40 on all the ball joint & torsion bar nuts (6) total.
5.Start with removing the (4) cotter pins located on the (2) ball joints, (1) steering linkage bar, & (1) cv joint/axle on the driver's side first. Use pliers and flat head screwdriver. Do the passenger side later after you complete the driver's side 100%.
6.loosen up the 13mm nut and bolt that holds the ABS wire onto the top A -arm. You will need a 13mm wrench to get the bolt from the inside. Place the bolt and back on the bracket.
7. Loosen and remove the (2) Allen bolts that hold the brake caliper onto the rotor. 3/8 socket. Place the bolts hand tight back into the caliper for safe keeping.
8.Remove the rotor and remove the axle nut cover that was fastened by a larger cotter pin.
9.Use a 36mm socket to remove the axle bolt with a cheater bar or impact gun.
10. Go ahead and remove the axle assembly and be careful with ABS wire is still connected.
11. You will need a 13/16 wrench to remove the steering linkage nut located under the truck in front of the shock. Leave it installed until you loosen up the other (2) ball joint nuts. This will hold the arms in place when you try to separate them.
12. Remove the lower ball joint nut using a 15/16 wrench.
13.Remove upper ball joint nut using a 7/8 wrench.
14. I hope you have rubber glove on cause it is going to get a little messy.
15. Use a 15/16 fork and heavy hammer to remove the lower ball joint first, steering linkage and then upper. The upper will be the hardest to separate.
16. Once you have removed the spindle assemble, you will need an 18mm wrench and socket to remove the lower bolt/nut of the shock.
17. Then use the same 18mm wrench to remove the ( 2) nuts located on the A-arm with the bushings. Take a look at the way the (4) token like washers are placed in between the bolts for reinstall reference.
18.You will have to pull the shock towards you away from the engine to clear the (2) bolts holding the A-arm in place.
19. Finally remove the upper A-arm.
20. Use a 10mm socket to remove the sway bar bracket under the lower arm.
21.Use a 13/16 socket to remove the nut from the lower arm.
22.To be continued..:dew: .
epix
Typhoon
i have the KYB's on my Ty.. bought them off tirerack.com
SyTyJedi
Jedi Council
I had the Belltechs all around. I replaced the rear ones with KYBs because the belltechs were bottoming out. My truck is 3" lower in the back and I guess that is too much for them to handle.
I think they would work better on a stock height or truck that isn't lowered as much.
They are for sale, only like 5k miles on them. KYBs are great.
12secondSY
Syty Killer :(
Mine has KYB's. Almost stock weight ty and it can take on ramps at 90 without horrible body roll. I also have a belltech rear sway bar. It rides great too.
0966Sy
Code what?
Call Eric at Turbotime Bruce, he had done some testing back in the day with the QA1 coilovers for the rear of his Typhoon. I've been wanting them ever sence, just orderd JS coilovers and this rear QA1 shock setup for the Typhoon. Just installed the rear shocks and springs a few days ago. Let me tell ya there is nothing that will compare to the ride and handling of these shocks and springs. comes with 12 position aluminum shocks springs and hardware to mount to the stock shock locations for about 450 shipped. This thing will not bottom out and i have a ATR swaybar and 3" belltech lowering springs + 1" lowering blocks. The shock adjustments are realy nice and you can go from realy soft ride to a realy stiff ride in a few clicks. No more bottoming out the rear, and no more shitty ride with regular gas shocks. I had the bilsteins before i changed over. Only disadvantages are you cant use the muffler back section of the atr 3" exhuast because the springs take up more room. you might be able to tweak it and make it work but not worth it imo. Im just running a turndown off the muffler. install for the shocks takes about 1hour to 1-/12
0966Sy
Code what?
Bruce, i hope your joking. You can change out the front shocks by just lifting up the front and removing them, nothing else. they will collapse to get them out of there. jezzz
Sy+Ty
Eric, Bruce is doing a ft. suspension rebuild on the Ty (control arm bushings, ball joints etc.) He's just looking to change shocks while he's in there.
Good info on those rear coilovers...may have to look into that myself. I didn't realize the rear setup could be had for <$500.
Sy+Ty
Sy #1874
Ty #1989
ashman
when i installed the KYB's on the rear of my sy, they were the same length as the stock bilstiens (both compressed and extended). my truck is lowered 3" in the rear (belltech springs and 1" blocks) and this put the shock at the extreme end of its compressed length. train tracks, pot holes and other small bumps/dips make for an EXTREMELY jarring ride.
