Which throttle body to get
gmcturbo
my throttle body has a bad shaft leak and im getting a new one. has anyone had any experience with the bbk or should i just get a new gm one. the part number i have is 17112618. does anyone know if that gm tb comes with tps or iac?
thanks
mike
93 ty #731
Sy769
No experience with that one.
I can only imagine what GM charges for a TB
I'd bet the better engineered aftermarket ones are cheaper :roll:
You could rebuild yours with new bushings if you are a cheapskate.
Matthew Little
tb
tb
I just took mine off because of this same thing, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2433535373&category=33558 , They are selling modded tb or you can send them yours, 52 mill bore and they install undersized bearings on the shaft to stop leaks(GN's are made like that from the factory) Horepowerguy@sbcglobal.net They charge 179/00 to do the upgrade and bore. Here is another link http://users3.ev1.net/~thor10/tbodytest.htm and there # is 512-336-2507. Hope this can help
