jwaller said:
ya alky might help. but if you rely on alky to provie the fuel that your inj's can't, your asking for problems when the alky system malfunctions. which can happen in any number of ways....not to mention, without direct port injection of alky your not getting a even mixture between cylinders.
Not proven, but also, if you use the right pressure & mixture of methanol, it may never be an issue. Most guys running a good setup of methanol injection read their plugs and don't see problems. Your results may vary, and I've not seen any conclusive testing proving this problem with alky injection, but I've seen a TON of happy customers. ::shrug::
Also, there are *many* failsafe setups for alky/meth/water injection using pressure switches & existing boost controllers. Mark had his setup so he couldn't generate more than 15psi of boost if there wasn't enough methanol line pressure. He ran 24+psi of boost on pump gas. Everyone mentions alky injection systems failing, but not too many people worry about their fuel systems or double pumper systems failing... ??
Also, running methanol will give you a LOT more injector overhead. With 50# injectors, going 10s won't be a problem.
Just giving you another point of view; i'm sold on the methanol injection stuff for street/strip turbocharged vehicles.
As far as turbos go - I went 11.0 @ 125 on 21psi or so, on a TE63. This isn't the norm, by far, but I think it gives you some more data to go on. You have to consider your buildup, your truck's weight, what boost level you'd run at. I'd definitely use something with the new GT technology. A 67 series turbo, with GT exhaust side would be my choice on a Sy with a mild buildup, going for those times. If you wanted solid/deep 10s, the 71 would be my choice.
