Which Valve Body should I use?
I have a rebuilt transmission originally out of Typhoon (this came out of Morgan's 'Duck'). I am going to install and clean up the Valve Body tomorrow. I have two VB's, my original Syclone VB and the Typhoon VB.
My original VB shifts great 4400rpm 1-2 shift and 4600 rpm 2-3 shift, and does WOT 3-4 shifts. Its still install in my 50K miles original untouched stock transmision (which still works 100%) Atleast know this is a known good, but it also still in my Syclone original transmission.
I have 92 Typhoon VB, one of the previous owner had rebuilt the transmission shortly before pulling it out. He complained of it not work right. While rebuilding it, I did fid the forward input drum was missing a part and was blistering the forward clutches. Otherwise the previous rebuild of the transmission hasn't turned up any other problems or hacks by the previous rebuilder. I am very sure the VB is an original Typhoon VB.
Atleast from what I have seen is Ty seem have lower shift point than Syclone's. I am not sure if its the VB or governor that is raising the shift points though. Syclone suposedly also have a slightly stiffer 1-2 shift. I am probably eventually going to screw around with raising my shift points as I have an aftermarket cam. The positive of reusing the Ty VB is that its sitting around and would be easier to cleanout and plus I wouldn't be messing with my original.
I also have muiltple Governors as well. Sy, Ty, TPI Corvette, and I also have a modified Corvette Governor (B&M Governor Recalbration Kit which I still have all the springs/weights for) I have heard the more HP you make the more it delay the shift points, so maybe my stock Syclone Governor will end up shifting higher anyways.
It wouldn't be the end of the world if I had to swap VB immediately, but I don't want to be doing a bunch of VB/Governor swaps while I trying to get my Sy to the Nationals this year either. So which VB or Governor would you recomend I use?
