Espritmike
The Ty has been bucking since I bought her under load 3/4 throttle and up. I have ordered a silicone vac set (due in January). I have new NGK plugs, msd wires,cap,rotor, coil, intake gaskets( upper and lower), valve cover gaskets, guide seals, oil cooler lines (both sets), oil filter adapter,water pump, serp belt, upper and lower hoses, turbo oil drain hose, oil and filter sitting and ready to go in at the same time. I want to send the injectors out for cleaning when apart also. I also want to change chargecooler hoses to 3/4" straight rubber and swap t stat to 180* and maybe hotwire cooler pump.I dont want anything too radical as far as mods but is there is anything I should also do when apart? Maybe adj. Fuel regulator? And walbro 255? Thanks mike
