While I'm in there....
Espritmike
The Ty has been bucking since I bought her under load 3/4 throttle and up. I have ordered a silicone vac set (due in January). I have new NGK plugs, msd wires,cap,rotor, coil, intake gaskets( upper and lower), valve cover gaskets, guide seals, oil cooler lines (both sets), oil filter adapter,water pump, serp belt, upper and lower hoses, turbo oil drain hose, oil and filter sitting and ready to go in at the same time. I want to send the injectors out for cleaning when apart also. I also want to change chargecooler hoses to 3/4" straight rubber and swap t stat to 180* and maybe hotwire cooler pump.I dont want anything too radical as far as mods but is there is anything I should also do when apart? Maybe adj. Fuel regulator? And walbro 255? Thanks mike
BoostedSUV
Re: While I'm in there....
What's your spark plug gap set at? I've had issues in the past with bucking under full throttle from spark blow out. I had to big of a plug gap and the boost was actually blowing out the flame. I re-gapped my plugs to .025 and it solved my problem.
BoostedSUV
I would also definitely put the 255 walbro in and an adjustable fuel pressure regulator in when do all the work...
Espritmike
Acually I was going to gap the plugs at about .027"-.028" (lets face it spark plug gapping tools are not that accurate). I am also doing a ZQ8 gearbox and updated shaft. I'll check the timing chain play (162k miles). What kind of AFPR should I get and what should it be set to (stock injectors)?
I also am going to replace the drivers side window guide and motor, stereo and heater core. Then off to my friends body shop to try to line up some fenders and cladding. I figure I will have about $2k into it plus my inital $5300. So about $7500 and it shuld be a pretty sound driver come spring.
I don't have much to add here except about spark plug gapping. I was told to use feeler gauges to check gap b/c the quality control on the gapping tools usually blows.
asrnj77
..hard to swallow
I think you might find some better prices and selections on AFPR's and fuel pumps by searching the buick boards. The turbo buick pumps and regulators for 86-87 regals will work on your truck as well.
Espritmike
I think I am going to replace the oil pressure switch while i'm in there also. Got most of the parts, i'm getting antsy waiting for the silicone vacuum kit I ordered from a member here.
