Whoops, what happened? Ostrich
boosteds10
Finally Fixed
Well I tried loading an ultimate chip program from tooky's website. I have a three bar installed and I also used a 3bar xdf file I got off of $59 forums.
The truck runs like total shit.
what went wrong?
Re: Whoops, what happened? Ostrich
you can't use code59 XDF to load a non code59 bin file, won't work.
You need to download the 58 xdf
boosteds10
Finally Fixed
Ok I got it working finally.
All the ultimate chips still run like crap though. I get a lower end stumble on acceleration. I used the starter bin from the forums and that is better in the lower end but stumbles a little bit under boost at around 10psi.
The tuning has begun
boosteds10
Finally Fixed
To update a stock bin for a 3bar map sensor what tables do I have to edit. I checked the map sensor constants on a 2bar and 3bar tune and they are different.
Is this the only table I need to change?
Thanks
skwayb
NWSTP
Not as simple as changing some tables to get a 3bar to work. It is code changes that have to be done to get a stock bin to run a 3 bar. Then all of the MAP tables have to be rescaled for 3 bar and then retuned. At this point you would be better off starting with $59. Grab a bin that is closest to your Injectors size. Adjust the F28 table (make all the vlues the same for every cell in this table when you change it) to get it to run close to 14.5-14.7 at idle after it is warmed up and then start to make logs with various driving conditions and run them through Autotune. That should help get some of the stumble you are talking about out. If it is way rich that can cause it.
Depending on how anal you are this can be a long ass process. It took WyoSyclone 168 bin revs to get his 40lber setup where he thinks it is pretty solid and he still has a few little things he is trying to fix. I am not even close to having mine dialed in. I think I am at 200+ revs.
boosteds10
Finally Fixed
Thanks for the info. I played with the ultimate chip tunes and none of them ran that great on my truck. Think im just gonna go the route you mentioned. My wideband will be here in a few days and ill go from there.
Thanks again
skwayb
NWSTP
This is known problem with thesome of the ultimates on some trucks. When I first got the V6 ultimate back in 2000 that is exactly what it did. Made me go out and learn how to tune so I could fix it.
boosteds10
Finally Fixed
yeah I actually found an ultimate bin that works...its one of the t3 race programs in V7. Little bit of stumble right before I get into boost but once its in boost it comes alive. Its like a night and day difference, cant believe how fast it is when its in boost from just a new bin.
Ill be learning to tune smoothing out this one. $58 & $59 are awsome!
For anyone thinking about tryin this stuff out DO IT. It took me all of two afternoons to be up and running feeling pretty confident with it
Syclone Rob
Its all ABOOT the SYTY eh
Yeah, I had the ultimate loaded on my ostrich, Last night Jeff explained and showed me code59. The first run was limited run as the truck would buck and pop at anything after 1800rpm as it was running super lean. Did some autotunes, and now it idles beautiful, under part throttle it already is starting to run better then the ultimate bin. Man, Lets just say, if you are planning on tuning (which I highly recommend) get yourself a Wb02, 3bar, code 59 starter bins, xdf and ads files and some reading... and tune tune tune....Big Thanks to the guys that make code59 possible and to Jeff S for spending time last night showing, explaining and letting me learn the hard way on coding code 59.:tup:
boosteds10
Finally Fixed
Yeah I just downloaded the Autotune sheet. From what it looks like you just paste your current VE table into the spreadsheet and it calculates a new one for you?
WyoSyclone
You also have to output the CSV file and paste it into Autotune... click on the 'instructions' tab at the bottom of the Autotune sheet and there's a nice diagram that spells it out.... it's amazing how fast you can get a truck up and running with it!
boosteds10
Finally Fixed
Oh man I didn't even see those tabs. Its amazing how much there is out there for these trucks with the production numbers being so limited.
This forums is the best!
