Why the gas smell?
92TyLA
hey guys i kinda need a hand on this one, My ty was running fine but 2 days ago wen I cut it on it started shaking and kinda acting like if it wanted to shut down, wen i gave it gas it just started tripping even more (felt like it had no gas) and some black smoke came out and a heavy smell of raw gas, and now everytime i turn it on it does that until it warms up then it stops.
any idea why?
any input will be greatly apprecciated:roll:
PPI Typhoon
DIY Madman
Re: Why the gas smell?
Perhaps you have an injector that is stuck open?
If you don't have a leak anywhere, then it's going into the motor.
Or you may not be getting spark, so the fuel isn't burning, causing the smell.
jeepruby04
check your map sensor, mine wasn't plugged in all the way and caused the same issue, look at the boost gage to see if it's showing -15 vac at idle, if it's good fpr????
92TyLA
i do have a good fpr RPM installed itabout 6 months ago. i'll check plugs in abit, i just got a boost gauge, i have to install it, but if it does or deosent work i'll come back:roll:
Thanks for the input guys.
berzerker
wookie
small fuel leak ?? look at the fuel rail / fuel pressure regulator for signs of a leak .
Jimmy
Banned
any idea why?
Busted diaphragm in FPR.Get new FPR.
92TyLA
FPR went out so soon....well ill see if i can get a new one, there is no leack anywhere, and it only puffs wen i start it up then the problem stops wen it warms up.
thanks guys
BoostedSUV
sounds to me like a leaky injector flooding out one or more cylinders and fouling the plug(s). Do you have a fuel pressure gauge? That will at least verify the operation of the AFPR.
Before you start it when cold. Pull plugs one by one and see if you have any fuel soaked plugs. This way you can isolate which cylinder it is and pin point the problem.
MRKING
New Parts for Old Trucks
If the afpr is set higher than needed for your given injector / chip combo , as previously stated IMO you've fouled a plug or two or three . Any fuel modifications should be addressed in the chips bin file .
By chance do you have a wideband 02 installed ?
92TyLA
not yet i just got the gauge but need the rest, still looking for a good one.
theres's no leak anywhere around as far as the eyes meet, im gonna start puling plugs now, FPR was set by RPM and it worked fine for about 6 months now, well until now that is.
