Re: Wickd6
Ty#1119
The truck came out with rebuilt stage 2 Hartman transmission and custom t/c converter, Motor was bored. 30 over with speed-pro pistons and rings, eagle H-beam rods, 4 bolt main, vortec heads with crane gold race roller rockers, 8.35.1 comp. vortec heads with modified intake. crane custom cam, billet fuel rails with #75 lbs injectors which inludes custom drivers in the ECM, Stealth 70 turbo on 3" inch downpipe wit external billet waste gate, AFPR kenne bell, autometer fuel pressure regulator, manual adjustable boost control (15-25 lbs(, A2A, Electric fan replacing the stock fan, a/c was removed to install turbo and down pipe. also has auto meter gauges for fuel pressure, boost and tranny temp mounted on a pillar. Air to air inter cooler, electric engine fan replacing the stock fan. I also installed a new front sway bar. Wheels and tires are 92 Corvette ZR1 replicas. This motor is capable of producing between 500 and 600 HP. Ostrich, turner pro RT5, Code 59, Datamster Plx Wbo 2.
www.code59.com
