S
scrapinthecoast
Guest
which wideband system does anyone recommend and what kind of effect to the performance does it have?
Wide band helps performance by letting you read into the tune. Just lets you know if engine is running rich or lean or in between.
Use in conjuction with Turbo Tweak chip for virtually self tuning capability. Tell the ECM what AFR to shoot for and it uses wide band for reference.
does anyone have pictures of were they are mounted?
Sensor can be installed in stock bung. Just swap out the narrow band for the wide band. Wiring should be described somewhere in here. Make sure to get one which emulates the narrow band.
Go this route, you won't be disappointed.
It will do a lot better if I can get a better boost launch. I can only get it to launch at around 6psi, I can do 12 to 14psi on the street.I like your sig.
That's fast!![]()
Anyone know if the AEM wideband can feed data into the ECU? I've seen the write up for the PLX one. I figure it'll use the same pin in on the ECU but does the AEM have an output? My truck came with the gauge already installed and I haven't poked around with it yet since I have enough other things to fix and work on. But now that the truck is almost running well again, I'm looking into having the wideband not only be a gauge but also feed to the computer. If I can keep the AEM one vs getting a new gauge, that would be awesome.
