Hey Don,
A few things...
- your IAC position doesn't change at all through the idle portions of the run... not sure what that is about since your idle speed is varying. IAC does change at the onset of TPS closure at the end of the run, indicating the ECM is attempting to make a dashpot-type adjustment.
I think that's where I bump the throttle to set the brake for launch.
- You MAY be close to running out of fuel since your injector DC is so high during the high-boost (torque) portions of your run. I can't remember what our O2 mv readings are supposed to be (I'm running the WB and 3bar so don't pay as much attention to the mv), but I think they may be high during these same high DC injector periods.
My truck has always done that, I wish I knew why. If I jack up FP it will come down a bit but runs rich on the wide band. But I'm just starting with tuning with the WB so maybe I can figure that out now.
- frames 96 thru 102 you may be encountering a lean condition based on the MV readings again.
I looked at my other runs from today and they are all the same. Happens right when I'm building boost for the launch. Looked at a couple from last year w/o the WB and they do it also. ??
- Interesting that your IAT's actually decreased during the run. Mine start around 98 degrees about build gradually to about 128f, but yours start at about 142 and go down to the 130's... you're pulling some heat out of intake charge at speed, but the higher temperature at low speed is interesting.. Duh, just realized that I'm running the Derale fan on my CAC wired to run all the time.
I can spray more alky and bring the temps way down but then I run rich.
edit... just noticed your sig says 'alky'... were you spraying during this run?
Yes.
Maybe Dig or Jeff will chime in and verify or tell me that I'm really full of *!#%** or have given somewhat useful observations
