tbauer03
TRBOBOX
I got my Typhoon back together after taking it apart because it was burning oil through the engine and leaving a watery oil mix on the ground by the exhaust. I took the lower intake off and re-sealed everything with new gaskets and RTV. Seems to not be leaking now.
But I think I damaged the wideband 02 Sensor because it is giving me weird readings. It may hold steady around 14-15 for a little bit then spike up to 19.9 and hold with out changing speed or throttle and it will fluctuate all over the board. It seemed to improve after about 10 minutes.
Also the ignition seems to break up and stumble a little bit when it is cold. I only drove it a couple miles. Perhaps driving it more will clean the oil deposits off or should I go ahead and just change all the plugs along with the 02 sensor.
