wideband 02 sensor questions
xcaliber
Well since no one has answered this, I'll try and help out, I'm no guru, but have been reading up on the WB02 alot
is it necessary? no, but is probably the best tuning tool you could ask for.
as for what it does, it reads the air/gas mixture percentage as in 12 parts air to one part of gas which is where you get the 12 to 1 or 12.5 to 1, or 14 to 1, etc, it tells you the exact mixture of air/fuel which allows you to start burning chips if you know how, and adjust the air/fuel to get the perfect mixture through the whole RPM range of all gears.
this is much better than the stock 02 senser which only tells you that you are runing Rich or lean, but gives you no idea as to how rich or how lean.
with wide band 02 you know exactly how rich or how lean you are running so you know more about how to adjust your fuel table.
I hope this makes since
Jamie Sanders
Sy 0252
Heber Springs, AR
bigtime
Sy-Ty Builder
I have one from tech edge that i use on a couple of cars.
It works great to get you in the ballpark on tuning. At the
track it also lets you know pretty quick if you are out of
range. BUT you still have to tune from all the other info
that is only accsesed by a datalog program. Tuning
consists more than just air/fuel. I use my mph from the
time slip at the track to see if there is a improvement, and
then tune from there.
Just my 2 cents.
I forgot. optimum a/f is different for all cars and
combinations.
