Wideband O2
Foot Performance
i was jsut wondering what it is. if you get a downpipe for a second 02 i am guessing it is just a way to monitor air fuel ratio more efficiatly but i do not know for surre and if you get one (downpipe with secondary 02) what is the most comen way to hook it up or just in genral what is it for??
thanks
juicehead9
93 Typhoon # 0973
Re: Wideband O2
to monitor air fuel ratio and yes you need a wide band 02 and you will need a second bong in the down pipe, you can get one welded in
cvcsmkr
Re: Wideband O2
thanks
you can put a WB in the stock location, and simulate your narrowband(stock) 02 sensor.
if you do this you will either need the equipment or send your chip to someone to patch the chip to recognize the WB.
do a search, & you will find a bunch of info, on how to wire it up, etc
Flyin Ryan
hated cuz he drives fords
Re: Wideband O2
It basically shows you where the sweet spot is in your tune.. shows how rich or how lean you are. Most have a second o2 bung welded into the downpipe and run that wideband o2 sensor to the cab of the truck for monitoring/data logging.. some put there's into the stock o2 sensor bung and well read the post above for that :)
Foot Performance
Re: Wideband O2
so do you just hook it up to a data logger or a secondary system i guess like a guage or an electronic controler or somehting like that
i am looking for a 3" downpipe so if i find one i will either weld a second one before install or buy one with it already on it
gjp
another post whore
Re: Wideband O2
I removed the NBo2 and put a WBo2 in its spot and used the NB simmulated output. For some reason I was geeting weird numbers on the DM. I picked up a JS 3" with 2 bungs so I can run both. The nbo2 for the Dm and smog and the WBo2 to tune off of.
Foot Performance
Re: Wideband O2
yeah i think that is what i am going to do i found a terry houston style wastegate down pipe dont realy know what that mean but it has the two 02 bungs
UR50SLO
V6+2=LSXCamaro
Re: Wideband O2
Yes.. use a 2 1/16 gauge in the pillar. I used a AEM gauge in my wifes Ty. When code 59 is public then you can tie it into your ECM and be real time with the widband.. You'll need it to properly tune your truck regardless of using 59 or not. You can weld another bung into the downpipe. Terry Houston style's good. JS's stock peice that bolts onto the stock turbo is nice.
Once you get the gauge and hook it up you'll need to learn where your truck should be at cruze/part/WOT...that's the fun part...
~Scott
