:tup:Can anyone out there give me some info:
I have a 1991 Sy and recently had 50Lbs injectors, P61 turbo and a 3inch catback
The truck will not start, it just goes cranking without starting and I noticed that the check gauges light comes on and will not start. I played around with the ignition switch and when the check engine light comes out briefly the truck will start; but if that engine light does not come on the truck will not start at all. I don't know what else to check. The battery is relocated on the back of the truck bed. If I leave it alone for about 1/2 to 1 hour the truck will start on the first try, but if I turn it off and try to restart it will not start unless that that yellow check engine light comes on but as soon as that Red check gauges light comes out the truck will not start.
Thank-you
Life has no rehersals and we are here for a brief time so take as much as you can for as long as you can & tomorrow does not exist and it's guaranteed to no one.
Thank-you
