255/55/16 on stock rims. will they look ok? thanks
NJ93TY Donating Member Sep 24, 2008 #2 Re: will they fit? PJ2397SY said: 255/55/16 on stock rims. will they look ok? thanks Click to expand... They will be approx 1.4 inches taller and 10mm wider, should work, make sure you check clearance issues if you install them
PJ2397SY Donating Member Sep 24, 2008 #3 Re: will they fit? i have 255/50/16 drag radials on it now and they do rub a little on the batt relocat cover.
NJ93TY Donating Member Sep 24, 2008 #4 Re: will they fit? PJ2397SY said: i have 255/50/16 drag radials on it now and they do rub a little on the batt relocat cover. Click to expand... 255 is the width, 50 is the % of sidewall height. so the 55's will be taller and rub more then they are rubbing now. Can you modify the battery tray to make them not rub?
PJ2397SY Donating Member Sep 24, 2008 #5 Re: will they fit? i have to look but i think the batt is pretty tight to the cover
