Will this cam help my combination?
grandam75
I have a Crane cam that came in an engine I bought for parts. I wonder if the cam would help my combination.
Cam has grind # HR-194/271-2-12.
Specs:
194*/204*@0.050
.407/.429 lift with 1.5 rockers
rpm range 1000-4500
Engine is stock except for:
replaced and hotwired IC pump
180* thermostat
minor porting on heads
port matched turbo-exh manifold
Shortblock:
2-bolt ARP studs
eagle rods
TRW pistons
I am planning to use STG ultimate chip + walbro pump.
jwaller
Evil Genius/SyTy Guru
Re: Will this cam help my combination?
not much better than stock but if it were free then I'd take it. if you have to pay for it get a 412. at least there are chips for it.
cloneman315
thats a cam i was gonna use,is it worth using when i build my motor and puit the l35s on it ,i also bought it cheap and would like to use it ,what gain between that and a 412
sytyguy
Moderated User
I agree with John.....you'll get better results and chip-compatibility with a Comp 09-412-8 cam. And the fact is, Crane cams are more expensive too - $239 for Comp, $275 for Crane.
FWIW, that cam is a Crane Compucam 184211. You can check out all the major shelf grinds available for our engines (as well as vin W 4.3s) - here.
