Windage tray or crank scraper?
4C FED
Absolutum Dominium
Does anyone make and has anyone ever used one for our application?
I've seen the trim-to-fit crank scraper, but has anyone used it successfully?
myclone
I thought about cutting one for a SBC up to fit our stuff but got to thinking about how it would mount on our late model rubber pan gasket.. IMO since all the gaskets for ours are one piece and have the "anti crush" metal inserts you wouldnt get a good seal. Prolly cause a oil leak sooner or later unless the rubber gasket was replaced with the old school cork one IMO.
Im thinking about doing a cut down SBC windage tray but since Im not planning on spinning the wee outta the eng I dunno if its really worth the trouble..
Just my .02
4C FED
Absolutum Dominium
My interest is more in keeping as much oil in the pan as possible.
So, I wonder if you could mod that scraper to mount just inside of the pan gasket so that gasket wouldn't rest on it?
I'll have to check my old block at home to see if there's any room.
Myclone, did you ever get my email about the modded pan dimensions?
myclone
Not a lot of places to mount a scraper other than on the pan rail IMO(least all the ones Ive seen mount there). Then again thats just my thoughts. Are you looking at keeping the oil from climbing up the back of the pan upon launching or are you just trying to get the oil off of the rotating assembly and back into the pan as quick as poss?
I dont recall a mail about oil pans so send it again if you would.
4C FED
Absolutum Dominium
I want to clean oil off the roatating assy. and put it back where it belongs.
Check you PM's.
Thanks
Mad Mike
SYCOSIS
Hey Rick, where did you get that signature video? It's great! Is there somewhere you can download stuff like that?
4C FED
Absolutum Dominium
Someone on another UBB posted it.
I bootlegged it. 8)
I don't know of any way to download an animated .gif other than FTP'ing it.
If you just try to save it all you get is 1 frame. :cry:
G
Guest
Guest
hey Rick;
I'm installing a windage tray on my new build....... a SBC tray cut to size. To clear the stud bolts holding the tray into place, I had to deepen the front of the oilpan 3/4". There are some pics of it in progress under my sig.
4C FED
Absolutum Dominium
Thanks for the pic's Roland.
I'm still kicking ideas around, not quite sure what route I'll go.
