Window gaskets
Treymen
I actually need the door window channel that has the felt on it. Need to replace both doors and cannot find these. These are the formed gaskets that run the entire length on the inside of the doors.
Also REALLY need the braided ABS delete kit.
Mprt Kla
Re: Window gaskets
I think you mean the window trim thats inside and outside the window on the top of the door? Tom (sportmachines) is working on a group purchase for them, GM discountinued carring them and there are some alternatives out there but apparently they suck. watch for the GP!
Treymen
Re: Window gaskets
Ya those are the pieces I need and yes, GM discontinued them some time ago. An undisclosed individual purchased the entire remaining stock around the country around the same time. They have been VERY hard to locate for awhile now. I'll keep an eye out for the GP.....Thanks
Quickstop [UK]
Combating adversyty.
Re: Window gaskets
You can get the rubber/trim but the internal metal runners for the window are impossible to find. Make sure you keep yours when you take the old ones out.
MAK
Re: Window gaskets
Treyman - You might want to check with LMC @ www.LMCTruck.com. They have an awesome selection of parts like that for our trucks. Order their free catalog and I bet you will have $2000 spent before you thumb through it. They do not carry Syclone/Typhoon specific parts but they have a lot of Sonoma/Jimmy parts we can use (any replacement window and door seal you would ever need, for example). Hope this helps.
TYTILIDIE
METH HEAD
Re: Window gaskets
LMC doesn't carry them anymore. I went through all this last March and ended up getting them at a local trim/clip shop. They sell resto parts. I got ALL of my weather stripping pieces for the doors and rear for about $200-$300. I did however, have to re-use the metal parts for the channels. If we have something like that local to us, I am sure you can find a similar shop near you. Your area is HUGE. If you want, I can go in to the shop here and hook you up with them. They had my stuff in stock and it all fit just right.
MAK
Re: Window gaskets
That sucks! I guess they need to take the parts they don't carry out of the catalog, if that's the case. I just got their new catalog and they are still in there. I will be needing some soon, myself.
Treymen
Re: Window gaskets
Yes these seem to be a real problem part for all s-10, sonoma, syty etc owners. Don't know why GM dicontinued them? One of my large Chevy accounts told me they get 5 requests a week for these parts. Sounds like GM could make some dough on these!!!!!
Sportmachines
Re: Window gaskets
We have had the same issue in finding them for our own trucks, customer trucks and restorations, so we have been looking for a suitable replacement and the good news is we found some! They fit perfectly, and are even better designed than the factory ones. We have a set on the shop truck right now so we could verify the fit and finish.
We are working out the details as they are usually only available in sets (inner and outer) We are trying to make it so that sets and individual pieces will be available. I hope to set up the GP within the next couple weeks.
And Treyman, we will have Braided ABS delete kits in stock soon as well.
MAK
Re: Window gaskets
I found the receipt - www.USA1industries.com - beltline window felts and channels 6 pc set = $120. I have not installed them yet so I can't speak of the fitment. I also bought them back in April so I am not sure if they still have them in stock.
Part # SKU16220
Treymen
Re: Window gaskets
Cool beans. On a side note, what is everyone using for foglight replacements? Took mine apart cuz I thought the bulb was replaceable....It's not
roswald21
Re: Window gaskets
i got mine from ebay plug play no cutting for a grandprix or gn not sure but fit perfect they use the same ones that are on our trucks
TYTILIDIE
METH HEAD
Re: Window gaskets
I go to Autozone and get the Blazer set up. I just throw the housing away and use the glass though. I am not sure why but it seems I go through these on a yearly basis.
Treymen
Re: Window gaskets
Part # SKU16220
I think thats it. Can you tell me what is included in the 6 piece set? I may no need all of that. I just bought all new door gaskets. I just need the window channels, which I believe are 2 pieces per door, I think......Thanks
MAK
Re: Window gaskets
It appears the kit is the entire seal/felt channel piece that goes around the sides and top of the window. The kit also includes the molded inside and outside seal at the bottom of the window which also has felt on the inner portion where the window slides as it opens. Very nice kit. Hopefully it all fits and works.
