Windows half work
Joey Allen
MUNCHKIN
I don't drive my Ty very much but the last couple of times noticed my passenger side window goes down and doesn't want to come back up. If you wait say 10 minutes then it goes back up. Anyone else had a simular problem? Thanks
NecroWolf
lost marbles member
Re: Windows half work
you could try lubing the track, or cleaning the switch. if it doesn't work right on both switches you might have the best luck lubing the track
'JustDreamin'
Dream: 6LV8 Turbo Bravada
Sounds heat related to me.
I'd certainly check the lubrication. That will certainly make the motor work harder.
Also, check the voltage at the motor. You might have switch contacts that are loosing a bunch of voltage, which will make the motor pull a bunch more power.
And if its well lubed and voltage is good (ideally 12V or so with the engine running), I'd say your motor is going south and needs replacement.
'JustDreamin'
sytyguy
Moderated User
Agreed.....motor going out.
A1 4219 = $29.99 with core exchange ($34.99 without core exchange)
Hood
blk00z28
Forced to by choice
Mine does it too. But hasnt lately for some odd reason. I havent wanted to take on the job of fixing it yet. :D
JKsSyclone
Hood
X 2...the motor is going out and $29.99 is a good price. :tup:
[thread hijack] Hey Hood....what about a left front window regulator for a 1995 Mercury Mystique? [/thread hijack]
sy#2716
SyTy 4 Life
it's easy took me about 30 mins to do it.
now on an f-body pain in the ass becasue you have to drill through the door and then drill the rivints and it is really tight fit when you go to put the new motor in.
hatrik8
Mine has the same problem on only the driver side. I have the new motors to go in, just haven't bothered yet. I plan on replacing the motors, cleaning it up inside and making sure the connections are good.
SY2932
Administrator
Based on your description, I would say with 99.999% certainty that the motor is shot. You can read up on how to fix it yourself here.
