Winter projects 2010
escofield
What are you doing this winter?
I get to put the Ty away for the winter, with multiple issues, sooo.. hope to address all of them, in no particular order.
Trans rebuild
driver window motor
catalytic converter.. or straight pipe
tune up
proper tune
rear wiper works but doesn't squirt washer fluid
Front bumper replacement
finish paint job.... rear gate replacement
new front tires
front end rebuild......
replace carpet, have one ready to go in
replace spare tire that blew
Do a better job installing the RPM cold air intake (make it look nice, maybe a different overflow tank and lines)
When I get all this in line....
Sell it because its a money sucking pig, or hold onto it and continue the love hate relationship??
There's always somethign to be done on this thing but these are currently the top on the list.
E
Fighting5thSVT
Re: Winter projects 2010
We will see how much of this list gets completed since I have yet to start and its already December....not to mention I only have about half of the new parts ready to go in boxes
ABS delete install
New water pump
Timing chain
Valve seal replacement
Powdercoat accessory brackets
New AC compressor
External WG
new fuel pump
Rear sway bar
Steering box and shaft
...plus I'm sure I missed something
qbnkiller
Conflaguration Specialist
Engine freshen-up
New cam
Clean-up the heads a little
New converter
New injectors
Maybe step up to a CompR66 turbo
Suspension
Ignition (new MSD box)
ziembic
Kicking off a frame off restoration. Probably going to be more than one winter.
Scalarrthu
I think I'm finally going to get myself a set of jack stands so I can start fitting in better with the group. LOL
In all seriousness, I think I'm finally going to get started with making this thing the monster it deserves to be. Going to do the turbo, swap to e85, and a bunch of other little things to clean things up some.
Silly
Banned
truck is being re-wired and I am re-doing the dash/radio bezel area.
Sean Krupa
Moderator
I finished installing Solid Motor Mounts and 3" JSM Downpipe.
Things left to do:
- LS1 Front and Rear Brake Conversion
- Valve Seal Replacement
- Top End Cleaner
TNPhoon
1of28
Off the top of my head:
Engine Refresh and clean the engine bay. New gaskets, timing chain, AFPR, Heater core, IC Pump, blah blah blah blah blah blah blah blah blah blah.
Install remote start.
Replace drivers side window motor.
Install 2" drop springs in the rear.
Replace rear drums.
Replace front rotors + ceramic pads.
Some general cleaning (removing some interior panels and getting rid of the dust).
Replacing the old rusting interior screws with new stainless steel screws.
Replace stock gauges with black/blue.
Install pillar pod + gauges.
Install LED light strip above "dash shelf"
Tint all windows.
Touch-up a few paint spots.
Repaint grille.
Paint GMC grille logo (either white or gray)
Replace headlights + fog lights.
Those are the things I NEED to get done this winter. I do have some other things that I WANT to get done, but time and $ will be the deciding factors on whether those happen this winter or next.
Blazerspeed
If I'm feeling froggy, and I can get our master bathroom finished in a respectable amount of time...
(My truck)
Body off the frame - this is going to be the trickiest part
Remove 3" body lift (don't ask)
Remove ext'g front axle and transfer case (4x4)
Remove torsion bar assembly
clean and prep entire frame
ravage the local U-Pull-it for the misc. parts I still need
(Sister-in-law's dad's truck)
Be my brother's bitch for 2-3 months so we can get his wife's dads '78 F100 Extended cab 4x4 finished. This is a full frame off restoration, and a huge PITA.
So yeah, I'm not getting anything done on mine this winter :D
(I should really start project threads for both of these...)
fauXGT
Brick Pilot
If I'm feeling froggy, and I can get our master bathroom finished in a respectable amount of time... Blazerspeed.
Good luck with that. It took me 6 months to complete our master bath last spring. Tile problems, changes mid project (I didn't make any changes:roll:) and waiting on materials.
Need to finish the shop, then get the trucks out of the weather. Then look into supercharger for ext cab truck. Get it ready for paint. Start disassembling the teal GT & figure out if its worth it.
TYTILIDIE
METH HEAD
For me it will be a little over winter. More like in to the spring.
Paint the damn truck
4L80 conversion
all new gauges
install ISAC
PLX (ditching LC1)
possibly rear disc conversion
and tune it for NATS
escofield
Truck is buried in snow at the body shop... not much getting done.. looking forward to warmer weather, getting it back into my garage and crossing off some of the stuff on my list..
ty166
decided to keep it ?? what did you ever figure out to do with your trans ?
escofield
Every time I wan to sell it everybody talks me out of it:lol: I'll change my mind again soon and you guys will have to change it back. As far as the trans goes, I'll have some money in 2 weeks if the cheap ones that were offered are still around, or save that money and put it towards a fresh rebuild for summer 2012. I'm living in the city again and don't really need a car anymore and I have a garage so I can tear it apart and take the time it needs to fix it up and learn a lot in the process.. Who knows
Whats going on with yours?
jeepruby04
I'll start with the sy:
install new brake hoses front and rear(left front leaking)
install zq8 gearbox and Jeep shaft
get it aligned
now for the sgt:
HOLY CRAP!!!!
brakes all the way 'round
replace suspension with zq8 stuff (in process now)
rebuild tranny/replace driveshaft (you should see this baby wobble on jackstands)
replace carpet
replace upper and lower ball joints
replace wheel bearings
get new tonneau cover
get new wheels
:banghead:
escofield
get it aligned
now for the sgt:
HOLY CRAP!!!!
replace carpet
get new wheels
:banghead:
I wanna do the zq8 and jeep shaft eventually... Hope you get it all done
ty166
2011 is gonna be my tys year, i can feel it :lol: . gonna drag it out out of storage in missouri (as soon as the 7 foot snow drift against my garage door here melts) and bring it up and finish the brake and hydroboost swap. put all the stock stuff back on i tore off thinking i was gonna make it something it will never be. then ship it down to scott and let him tune it. and just drive it. if i wanna beat the shit outta something i got my 59. let me know if you need tool or help, i had my trans in and out twice now and ill be doin it one more time to put the stock conveter back in.
where you at in the city ??
TYRODD
My ass. Look at it.
a/c heater box delete-almost done
new heat only heater core-done
alum. waterpump
a/c bracket delete
3in SS exhaust
3in JSM DP
Handmade CAI/box
misc. powder coating projects
rewiring several items under the hood
The main idea is to get my engine compartment even more neat and clean in time for DENVER NATS 2011! :thumbsup:
