Re: Wire colors for Greddy Turbo Timer install
Found this:
The basic functions of the wires go something like this:
Red: This goes to constant 12V. It supplies the TT with power, and is used to keep the ignition line at 12V after key off. It must be connected to a good 12V source that is capable of sourcing current
Green: This wire gets connected to the ignition switched 12 V source. When the turbo timer detects a drop in this voltage, it will source voltage to it for the amount of time programmed in the timer. This will keep the engine running.
Black: The ground for the turbo timer
Grey: This wire gets connected to the emergency brake switch. It should have 12V to it when the emergency brake is DOWN. This will turn off the turbo timer if the brake is put down. If someone were to try to get in your car and drive it away while the TT was running, they could keep adding time to the TT until they got to where they needed to go. By connecting this wire, they will turn the car off when they release the emergency brake. This is a security feature and should always be used.
White: The white wire is used to get the O2 sensor readings. Like I already said, I will not be using this wire
Blue: I am not sure of this wire's function. I believe this should be connected to a switched 12V source which is live when in ACC (instead of run). I did not connect this wire in my install, but will investigate its purpose.
