wire connection
$yty
was changing wheels on a friends typhoon that he just bought and there was a wire by the driver side rear tire right by the frame and it was disconnected...everything on the truck works good.
so what could this wires lead to.....
ty166
Re: wire connection
air/level ride, there should be a compressor mounted on the outside of the left rear frame rail behind the rear wheel under a cover, also should have air shocks on the rear, in not someone most likely eliminated it and left the wiring .
$yty
Re: wire connection
i will have to check that>>thanks for the quick reply
is there a benefit of having it on versus removing it??
powercat6
Re: wire connection
Right now it's just extra weight since it's unplugged. Most Tys have had this disconnected due to leaking air shocks that were replaced with regular shocks or so the suspension could be lowered.
Throws
Re: wire connection
Agreed. Mine sits in a "box of original parts". Best place for it.
-P
Syclone22
Re: wire connection
A quick check at the shocks will tell you if the air system
is there the shocks will have a 1/4 inch nylon tube hose at the side
if these are not there they have been replaced with just gas units !! :rotf:
$yty
Re: wire connection
I connected it back while changine the wheels...but nvr noticed a change in ride height nor ever hear the compressor workin....so would u guys suggest leaving it on or remove it and add different shocks...
