wiring for ic pump/elec fan
cvcsmkr
the weather pack at the brake booster has a green/orange/black.
i beileve the green is the pump positive and the black is negitive.
what is the orange for?
which wire is controlled by ecu, for run times, turn on/off??
#2875
built, not bought
Re: wiring for ic pump/elec fan
i can't recall the colors and i didn't drive the truck today but one is the low coolant sensor on the stock lower heat exchanger and the other 2 are + and - for the pump.
Jamerjoe
I just hooked up my fans. Above the dist. there are 2 relays. The right one has a yellow wire. You want to cut the wire and ground the end coming out the relay which will keep the IC pump on all the time when truck is running. The other end you want to run to another relay (40amp waterproof) to turn on the fans. For the fans run the postive straight to the battery and put the relay on the ground. Then all you got to do is setup the bin file to turn on the fans at the right temp. The fans work great.
cvcsmkr
okay well the green has a goofy 90* elec fitting on end.
this wire is right by idler arm.
the orange and black go to another weather pack, but this is by the pitman arm.
so i am assuming the green is for the low coolant can anybody verify?
i would like to use one of these wires since i already have my wiring there and its all hacked up, ready to go.
cvcsmkr
that helps, but i really would like to use one of those wires and the weather pack by brake booster. if no one can verify what wires do what then ill just use your wiring.
thanks for the info.
cvcsmkr
i dont quite get it.
if you cut that yellow wire so the ic pump runs all the tme.
wont you be cancellng out the settings in the bin file?
i want to be able to use all the bin file settings to signal my fans to turn on.
mostly for start up, i want the fans to be delayed 5 secs or so, while engine is turning over.
