Wiring for intercooler pump(Bosch)
2500avalanche
Well-known member
I am seeing if someone can help.
I have a new bosch intercooler pump. I do have the connector to connect to it, but having a problem figuring out what is positive and negative. The connector (that I have to solder to the OEM connector), has a red wire and a red with a black line wire. It is a ford connector. What color goes to the OEM color for the wires?
Slyclone
Well-known member
Re: Wiring for intercooler pump(Bosch)
Do you have a multi meter? or a digital volt meter
Probe the 2 terminals you think they are, key in ignition on.
Of course ground out one to anything metal and poke into the terminal and see which is hot.
to me red is always hot, red with a black is a ground
The syclone or typhoon might be different if I remember the wires are blue/green?
canadian
sy in progress
On the pump itself there should be arrows pointing in the flow direction. For instance, the Johnson intercooler pump I have looks like this:
You can just barely see the arrow on the rear nipple. That's where the water needs to come out. You should be able to connect a few alligator clips to the pump leads and feed it a little water. Check to make sure that the water comes out the right port. If it doesn't, reverse the leads and confirm.
The stock intercooler pump wiring has orange, black, and green. The green wire goes to the spade terminal on the lower I/C core. Orange should be 12v and black should be the ground.
2500avalanche
Well-known member
Yeah,
It has the arrows, I guess I just need to make sure when I solder the OEM harness wires to the connector for this intercooler, I have it correct.
powercat6
Per the drawing looks like the negative is closest to the the discharge port.
DaveP
Permanent Magnet D.C. Motors will run in either direction, depending on polarity.
Centrifugal pumps, (like most I.C pumps popular for inter cooling) are rotation-sensitive. They may prime and pump if rotating backwards, but not very well.
If you are unsure about polarity, hook it up temporarily and power it up. Look in the inlet. (The center opening). The rotor must be rotating in the direction the flow indicates, or 'outwards' through the outlet.
This pump will rotate clockwise, looking in the center inlet, if polarity is correct.
Checking costs nothing.
2500avalanche
Well-known member
Thanks! Will do this tonight!
